How to adjust Track Bar?
I saw a video on how to adjust a track bar and had a quick question.
In the video they removed a bolt from the track bar and let it drop down. They then turned the steering wheel back and forth 4 or 5 times which centered the front frame over the axle. Then they adjusted the track bar to the new length and re-attached it.
Is this the best way or should I measure the difference on each side and divide that number in half and adjust it that much?
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
A lot of this depends on which track bar you have. The ones that you adjust while installed (like Synergy or TF) are super easy due to their turnbuckle and/or sleeve designs. Others like RK are a pain in the a$$ and are easier to just completely remove and then reinstall. the method you described might be easier for some TB's if the jam nuts are easily accessed while partially installed (or installed) on the jeep). Get the body centered over the axle (measure to confirm), adjust TB to desired length, install and torque jam nut.
If you have fenders, it might be best to stand a level straight up on the tire, and then use a tape measure to measure from the upper spring perch to the tape measure. You just need a fixed point (the spring perch) and make sure you're measuring out to a similar point (hence the level).
![gak](https://www.jk-forum.com/forums/images/smilies/icon_crazy.gif)
![Wink](https://www.jk-forum.com/forums/images/smilies/wink.png)
![Thumbs](https://www.jk-forum.com/forums/images/smilies/thumbs.gif)
Thanks for the advice. I have the RC TB which has the clamp and sleeve. So sounds like I just need to loosen the nuts and adjust it until my frame is centered over the axle.
![2 Thumbs](https://www.jk-forum.com/forums/images/smilies/2thumbsup.gif)
You're probably not moving the axle enough, but keep in mind when shifting the axle you're also shifting the DL just a bit. You may need to readjust the DL length so your steering wheel is perfectly straight again.
Former Vendor
RK=Measure once/cut twice, often times more.
The Teraflex TB I got went on painlessly, was a breeze to adjust twisting the adjustment with one hand, and best of all for my preference it is maintenance free and doesn't require special grease or need extra attention to the joints. Install and forget about it, just how I like it
There is a substantial difference in strength between solid stock steel with adjusting ends and jam nuts than tubing with an adjusting sleeve. I feel that the strength difference is worth the added 5 minutes of install time and needing to grease one joint every 6 months but others might feel different.
Adam C
![Broke](https://www.jk-forum.com/forums/images/smilies/broke.gif)
![rotflmao](https://www.jk-forum.com/forums/images/smilies/yelrotflmao.gif)
I really have no loyalty to any manufacture. My jeep is a big mix of parts. When it came to the TB, the RK fit my need, and I felt ok with the anti-wobble joint in that bar. The price point fit my need, and although I didn't really like the double-adjustable ends, once set I was good. I don't really think it was a "cut twice or more" situation like other things.....in fact, the suggested measurement was spot on. It's been fine for me for a couple years now.....although wasn't thrilled with the PC from the very start....as the whole world complains about. I just couldn't justify spending a crap load more for somethings else.....mainly cuz this was my 3rd stab at a trackbar....
. 1st one was cheap Pro Comp POS till I learned about the crap I didn't know.....then was the Synergy TB which failed on my frame side within a year and I got pissed off about after that and their BJ's.
![crazyeyes](https://www.jk-forum.com/forums/images/smilies/crazyeyes.gif)
That money could be spent on smarter things, like putting it towards traction devices. I run the RK in the rear and JKS up front. No complaints about either.
