HOT OIL LIGHT/ what do i need to fix this
Originally Posted by shriekk
what tunner do you recomend? can you link some? is there anything else i'll need other then the tunner chip/device
Check out the rest of the cooling system. Until you get the dedicated transmission cooler, the cooling system is also cooling the transmission.
Do the fan and fan thermostat work right? No mud/crud in or around the radiator? Coolant full and mixed correctly? Water pump doing its job?
dedicated transmission cooler was installed today the temp gage never moved on the dashboard when it over heated. cooling system seems to run fine the mechanic couldnt find anything wrong he said i caught it just in time
he did a software update ( will get more info on that donno what he did)
transmition flush
installed a dedicated transmission cooler attached to the front of the radiator.
transmition flush
transmition flush
transmition flush
Try the same driving conditions that caused the hot oil warning to come on before. I'll bet it won't come on now.
