HOT OIL LIGHT/ what do i need to fix this
lots of write ups on this subject little background on my jeep that i have its a 2007 JK serra unlimited 3 1/2 inch lift 35inch tires 4:10 gears (automatic)
this light came on one day on the highway was in normal drive going about 75mph on the highway. pulled off let the vehicle cool down and creeped it home.
2nd time it came on I was towing a 18 foot bayliner boat dont think it weights more then the capacity of 3500 lbs.
i'm having the transmition cooler installed today is there anything else I need to do to the jeep to keep this light from coming back
both days was about 90 outside
took it to a shop for the install of the cooler they looked at the transmition and cant see any damage just said I fried the fluid that he can tell
cooler, softwear update and transmition flush was a painfull 600 bucks
will I blow my transmition if I try and pull that boat again is what i'm wondering
while pulling the boat the check engine light came on with codes p0740 and p0218
Buy a tunner to set up speedo... A tunner with gauge, like vivid or bully dog...
A regear will help also...
I hava a 2007, auto with 35s... I had 4.10 a my trans used to get hot... Now with 5.13 the thing is better... If you drive one regeared, you will see that it worts every penny!!
The cooler should take care of most of the heat issues. I would also install a transmission temp gauge.
Originally Posted by shriekk
did the flush and the cooler is geting put on tonight as far as the speedo yea my gage is 5mph faster then what the spedomiter shows
