Hot Gears
Old 02-13-2011, 08:30 AM
  #31
u-joint's Avatar
Originally Posted by Olean NY Jeeper
...I have 6 spped so I sholdnt have to worry about transmission and reprograming stuff...
You should at least pick up a ProCal so you can recalibrate your speedometer.
To the OP, please do keep us posted. I hate to hear about your situation. I do hope it works out for the best.
Old 02-13-2011, 08:33 AM
  #32
captjay's Avatar
Originally Posted by bchoate79
I have taken programmer out and updated i have put back stock and then even tried larger tire sizes still does it. Don't believe it programmer because it was fine for about five hundred miles then all of this started tranny oil smells burnt but dealer says its under a load
well that sucks, it was just a thought. hope it all gets figured out.I must have missed the 500 miles part somewhere.
btw, do hear any noises on acceleration or deceleration, like whining noise?
Old 02-13-2011, 08:51 AM
  #33
bchoate79's Avatar
yep i am hearing a whining noise on acceleration just a little.
Old 02-13-2011, 08:55 AM
  #34
thrshr01's Avatar
...I took front drive shaft off and front seemed to have drag still but then i took off brakes and all was fine front...
You took the brakes off and everything felt good? When you re-installed the driveshaft were the brakes still off? Your brakes might be dragging. Are your brake rotors discolored (bluish or some dark spots on it)? Are the pads glazed?
Old 02-13-2011, 09:01 AM
  #35
bchoate79's Avatar
Took brakes off with shafts still on a little less drag but not fixed. definitely not the brakes.
Old 03-29-2011, 09:38 AM
  #36
will16's Avatar
Just found this thread because i am planning on doing my gears. Wanted to see if the OP ever got to the bottom of this? I hope so and would love to hear what it was.
Old 03-29-2011, 10:32 AM
  #37
orfanidisnikolaos's Avatar
i am planning to do gears as well so please update the thread to let us know what it was.....
Quick Reply: Hot Gears
