Hot Gears
Old 01-22-2011, 07:23 PM
bchoate79's Avatar
Default Hot Gears
Well i had new gears installed about five hundred miles ago . I broke gears in driveing about ten miles to work and same home for times a day and today i pushed a little further about 30 miles and had a hot smell like something burning and now jeep seems like im drag around a boat anchor didnt smell like gear oil just like some thing hot wonder if gears set to tight also gears sound louder now and tried to put hand on back axle and it was burning hot couldnt keep it there but front was about half as hot figured it was because rear is drive and fronts just spinning Thanks any thoughts
Old 01-22-2011, 07:29 PM
ronjenx's Avatar
Sounds like you should take it back to the installer and have them open it up for an inspection.
Old 01-22-2011, 07:36 PM
bchoate79's Avatar
Plan on it monday just got to go one more day with my baby hurting
Old 01-22-2011, 07:42 PM
Biginboca's Avatar
Sounds like something is amiss with the gear install. Please post up what you find out on Monday, and good luck!
Old 01-22-2011, 07:52 PM
bchoate79's Avatar
sure will had a shop in san diego do wont name yet will see what they do first had four wheel parts do my tj only took them three trys hope i dont have same problem at other shop ill post Thanks
Old 01-26-2011, 06:15 PM
bchoate79's Avatar
I took it back in to shop they opened front and rear diff and completely took apart and couldn't find any thing even had me go take a look. Jeep still feels like under a load all the time and tranny down shifts at any movement of the gas pedal any ideas.
Old 01-26-2011, 06:31 PM
tslewisz's Avatar
Pinch a brake line or foul up the emergency brake cable?
Old 01-26-2011, 06:36 PM
bchoate79's Avatar
Nope thought that to tranny oil smells a little burnt though.
Old 01-26-2011, 06:37 PM
peanut's Avatar
Do you have superchip or any other programer ?
Old 01-26-2011, 06:45 PM
bchoate79's Avatar
Yep I have hypertec programmer even took it out and reinstalled but still the same.
Quick Reply: Hot Gears
