Homemade Highway Pegs.
Per side: 1- 7" 5/8 hex bolt 1- 5" x 3/8 galvanized eye bolt (get the one that's more expensive as it has a stop at the top) 4 - 5/8 rubber grommets 3 - 1" bushings 1 - 3/4 bushing 2 - 5/8 galvanized washers 1- 5/8 nut and some lock tite. Slide the grommets over the bushings (you can use galvanized pipe if you want and slide the grommets over that). Slide the bushings(or pipe) over the bolt and see pic for the rest. 10 mins max once you have the doors off and a tool set handy.
3/4" bushing goes closest to the nut
Not sure why anyone would need to hang their leg out the door. Would be a great position to be in when the guy T bones you. Good by leg. Why is this cool?? Just curious.
