Hmmmm what to do
Hmmmm what to do
Hey guys. I am looking to invest in 37" tires and a lift/suspension kit. What all other parts would I need to do this and what size lift? I am also getting flat fenders. Thanks
Id look at 3.5" and up of lift - Long or short arm depending on your taste and wallet. Appropriate bump stop setup for 37" and flat fenders.
You'll need new shocks as well and depending on what you already have done to your JK you will need C2 Gussets at a minimum. Then gears depending on where you are at presently.
AEV Procal or tuner to change tire size to get your shift points and spedo back to range...
If you wheel you'll most likely need a new front driveshaft if you lift 4" and up with a 4dr and auto transmission.
It never stops~
Best of luck-
john
It never stops~
Best of luck-
john
