Hill start assist shut off???
The directions how to turn it off start on page 375 in the owners manual but... I don't think that is your problem. The brake pressure is released in proportion to the amount of throttle you give it (page 373). The 3.8 motor has little or no low end torque and is easily killed if you don't give it a lot of throttle when taking off, flat ground included. I have a '08 and I kill mine frequently because I'm used to diesels.
well i guess i know now why i didnt know about hill start assist........
http://www.jeep.com/en/search_result...start%20assist
it started in 09 for the JK, my 07 doesnt have it. Oh well, been wheelin for 12 years with out it, i guess i can keep wheelin with out it.
hill assist is available in all transfer case ranges. It's extremely useful off road. If you've not found it nice to have off road, you're not wheelin hard enough! I can work a clutch pretty well, but i do love the fact i can have that few seconds of stability when on a obstacle or in a bind on something. Works very well.
ormhof.org/inductees/Brian-Chuchua.htm[/url]
tell him he didnt wheel hard enough! ------^
So whats the point of the historical lesson?
Unless you are in 4-low or manually turn off the ESP (pushing the button only partially turns it off, completely off is listed in the owners manual) then the traction control will limit your wheel spin by using the brakes and reducing engine torque. I drive around with mine 100% off, so I drive it however I feel off road.
No, manual trans only. Gearing is probably the problem, unless you are off road and your traction control is then your problem
Not sure what an old Baja racer has to do with anything? About 1% of their time I'd say is at a stop. And anyway I said 'if you don't find it nice to have off road'. I didn't say you couldn't off road without it, or shouldn't off road without it.
Dont get me wrong i am all for technology helping out off road. I was happy to see Jeep finally go to the BLD, after Landrover and Hmmer have been using it for decades. HSA, is a good thing, but to say you cant wheel hard without it is a little overboard.
"From the mid to late 1950s Chuchua continued to race his jeep and participate in club runs in Southern California. He rode as a member with The Chuckwalla Jeep Club. His Jeep was the first to climb the Devil’s Slide at Pismo Beach in the mid 1950s and in 1954 he participated in the Rubcion Jeep Jamboree. He also started to use his Jeep to explore further regions of the globe and in 1960 he drove his Jeep from La Habra, California through Mexico and Central America all the way to the Panama Canal"
Rubicon Trail...... Central America..... NOT ALL BAJA
Not sure about your specific situation in Moab but just so you no, when you are in 4wd low, you do not need the clutch to start the jeep, just have it in 1st gear, turn the key and it will start climbing. No clutch, no rollback. Works like a charm. And I like HSA. It helps on road as well as off.
I can work a clutch just fine with out it but it is usefull if you learn to use it to your advantage. Kinda like the internet, you can ignore it or use it for good things to help you out even though you can get by with out it.
