High steer with ultimate dana 60.
Hi guys i have the UD 60 front axle on my jeep and im wanting to do high steer to get a little more clearance for my tie rod and psc ram. The axle came stock with the high steer arm already mounted for the drag link. Can i just drill out the top of the high steer arm with a reamer and mount the drag link on the top and then do the same with the tierod drilling out the knuckle mounts to then flip the tie rod? If so does anyone know what size reamer to use? The draglink and tie rod are made by Synergy. Here is where they sitting now.
If you flip the draglink, you will ruin your steering geometry and cause your draglink to hit the frame under compression. That is already considered a high steer setup, it just mounts below the arm so you could use the stock draglink.
