hi-lift mount
Old 01-05-2015, 02:30 AM
JK505's Avatar
Originally Posted by phil0352
Where in Manassas are you at? Thanks for the ideas all.
I'm actually not in Manassas. I'm just about 10 minutes south, in Nokesville.
Edit: Are you the 4 door Rescue Sahara usually parked near the Autozone parking lot off of Sudley Rd? Every time I go to refill my burnt oil, there's one parked in front of some store next to it.
Old 01-05-2015, 11:43 AM
Grand Umpah's Avatar
x2 on mounting between the roll bar in the back, like AR JK Rubi's post.
Just get some exhaust pipe brackets and a couple of steel straps that you can bend to shape, and you'll have a low-cost mount that works very well. You'd think that this location would be in the way, but it's high enough to stow cargo bins below and low enough not to block the rear-view mirror. And it's easy to get the jack in and out without scratching paint or breaking windows.
Old 01-05-2015, 12:39 PM
Heakle's Avatar
Inside mount on the top of the roll bar with a Jeepswag.com mount. Really out of the way and I added my pull pal arm, a shovel and ax. No rattles or squeaks, relatively easy to get out when needed. The only downside is that you put a dirty item back inside the jeep for the ride home. That's why I have a large water can outside. Click image for larger version
ID:	590724 Looking up from the ground behind the jeep Click image for larger version
ID:	590725 From behind showing how it's up inside the top
Old 01-05-2015, 12:51 PM
trouty33's Avatar
Originally Posted by Mclerran11
How does it fit there? I think that's a perfect place to store it but I have no idea how you got it in there...
I will try and post pictures as soon as I get home.
Old 01-05-2015, 01:43 PM
trouty33's Avatar
Originally Posted by TheNoob
Can you post pics? I would love to fit my extreme hi-lift there. Since the tailgate options don't work for it because of the huge square base.
Here are the few I could get. Maybe able to get more tomorrow in the daylight.... I slide it in top first from the passenger side. Click image for larger version
ID:	590738 Click image for larger version
ID:	590739 Click image for larger version
ID:	590740 Click image for larger version
The first 2 are taken from the passenger side the last two are from drivers side. Again keeping in mind I drive an unlimited.
Old 01-05-2015, 08:45 PM
Former Member
Benm1020's Avatar
I'll get a pic when i get home but i have it on the hood, i believe 40 bucks from ebay.
i like it on the hood the best bc 1. its outside the vehicle not getting the inside muddy and 2. I already have a heavy tire carrier in the back and i wanted to even out the weight distribution and put it closer to the front. I personally like the look more of it in the rear on the tire carrier but i dont want so much weight back there sagging my springs and giving it a non leveled look.
just something to consider
Old 01-06-2015, 04:30 PM
MRGeep's Avatar
I've got a KargoMaster rack and I recently moved it to the rear crossbar on the rack. I use the Hi-Lift tube mounts and it holds it great. I did have to bungee the base down since it was rattling like crazy. I'm sure it used to when I had it mounted on the light bar above my front bumper, I just couldn't hear it as well.
Old 01-07-2015, 07:01 PM
KenHolden's Avatar
Im liking all of the northern VA folk on here. i just got a new hi lift too, no idea how i want to mount it on the back though. ive got zero room in the cab
Old 01-07-2015, 07:57 PM
TreyJK's Avatar
I have mine on the hood because I like the look, keeps weight off the back, keeps the inside clean, and the jack is pretty much protected from mud or road salt. I use the ACE brackets and have been really happy with them.
Old 01-09-2015, 12:23 PM
phil0352's Avatar
Well it looks like Sanata decided where I am going to mount it. He came by late with a hood mount for me.
Quick Reply: hi-lift mount
