Hi-Lift install on the JK
the tail gate opens fine, just at full open the tip of the jack touches the rear corner panel.
as far as the antenna mount... here is post about that... https://www.jk-forum.com/forums/show...2&postcount=17
hope that helps
as far as the hook...
.... argh matey argh!
hope that helps
hope that helps
How is the SWR with that antenna mount? I read about antennas needing a ground plane, with RF grounding straps all over the vehicle. Or is that mostly for HF?
I'm a new ham so I hope I have the terms right.
Thanks,
Lonny
Thanks,
Lonny
hi jack mount
looks cool, a little to evasive a mounting spot for me. drilling into the body and cutting the plastic hinge covers...OUCH! so no conserns with bending, stress, corrosion etc?
i too mounted a hi jack on the jk with same mounts but choose a less aggressive location (to the body that is)
