Hey, Dynomax guy...
#51
I never had mine dump before the axle. I wanted it to go straight out the back from the start bc of my kid riding the back all the time. And mine's pretty loud. I love the sound. But I never "don't know" it's there.
#52
Thats why mine is for off road use only. If you read the description of the product, it mentions for off road use only.
#53
Heres some quick videos right after the install. Will try to get some better ones.
https://youtu.be/AEVk5skSYUA
https://youtu.be/xz5hoGHJqZw
#54
Shouldn't be an issue. This is mounted to the similar layout as a 4 door.
Great pics.
It can be a bit loud, but I just crank it up. Ha!
No it is a state issue, a good site to see what is "legal" or not "legal" by state.
Many states want a muffler, some states want the exhaust to dump out back... but then there are some cars that dump out the side, so it gets murky.
Lift Laws | Suspension Lift Laws By State
Great pics.
Mounted the Evolution Competition on my 2 Door. It wasn't too bad of an install. I did have to cut the middle pipe down a bit. Only thing im concerned about is the heat next to the EVAP canister or whatever it is, what do you think? I also think I might cut down the exhaust tail pipe to give the hanger isolator a better fit.
Overall, it sounds a lot deeper and definitely gives a better throttle response. We will see what it sounds like after the break in period.
#55
Awesome. Ill keep you updated, if i have any issues with that there. I had to grind out the EVAP skid plate a little to get the brack on there. Im used to loud. Had 37s on an F150 with a full exhaust, too include headers. The noise of the tires are music to my ears.
#56
Then you are fine!!!
#57
#58
Cut the intermediate. Resonator back goes. Just dont cut too much like I did.
#59
#60
If you mess up, you can order a new intermediary pipe from the DIY kit. But they range from $40-80. And Autozone doesn't carry them. So you'll be without a muffler until it ships. If you're dumping before the axle you have more room to play. A straight pipe out the back requires it to be pretty precise. 3 parts have to all line up with their associated hangers. The hardest part was removing the old setup from the hangers. Wd40 and a prybar.
