Hey all track bar question here
Old 07-11-2013 | 07:56 PM
tankatoy's Avatar
Yes streeing stab yea deff nothing else i really should look into it. But since i change the streeig stab i havent had a prob . Just the track bar bushing is worn and you cant replace the bushing and have the same results.
Old 07-11-2013 | 08:11 PM
red2010rubi's Avatar
The JKS is really nice and much beefier than the stock
Old 07-12-2013 | 07:14 AM
ChesterJFK's Avatar
Teraflex monster is also a good upgrade!
Old 07-12-2013 | 07:18 AM
Maertz's Avatar
Dont get rugged ridge lol
Old 07-12-2013 | 07:48 AM
JKred's Avatar
6" of lift and factory trackbar?
At that lift height, you really should be running some form of steering correction front (and matching rear roll center correction). My suggestion would be flipping the drag link to the top of the knuckle, and raising the axle trackbar bracket by 3". You should also run an adjustable trackbar as you will not be raising the axle mount enough to keep the factory trackbar.
If you raise the trackbar at the axle you can not use the teraflex trackbar unless running 4"+ of bumpstop. The bend in the trackbar will hit the pitman arm at full pasenger compression. RK or synergy trackbars are straighter and work well with high steer.
If you raise the front 3" for high steer, I highly recommend raising the rear 3-4" as well if you havent already. If you do not you will have negative roll center's front and rear and your handeling will get worse, not improve.
Old 07-12-2013 | 08:39 AM
tankatoy's Avatar
The track bar i have now is from RR its done lol
Old 07-12-2013 | 08:41 AM
tankatoy's Avatar
I posted to see what thoughts other jeepers had about teraflex front track bar
Old 07-12-2013 | 10:33 AM
Rock Krawler Suspension's Avatar
Former Vendor
Originally Posted by tankatoy
Hey all i have been looking in a track bar for my 08jk rubi i have been looking at the many options but i keep going back to the teraflex track bar . Because my rubi is lifted 6inch's im kinda limited to what i can get. Any thoughts ?
From what we gathered you have a 6" kit on your rig, if you do not have any steering correction on it now your steering is probably at some crazy angles. Like was stated in one of the comments a high steer kit would be very beneficial to you.Take a look at our Ultimate steering package, It has everything you would need to go to high steering and also includes our double adjustable track bar. This kit will take a lot of the stress off of your steering box that your current setup is putting on it.
RK
Old 07-12-2013 | 10:57 AM
tankatoy's Avatar
Just looked it up looks and sounds like a solid product . But it will cost prob with labor about 1000 bucks which is not in my price range at the moment ....
Old 07-13-2013 | 01:35 AM
kjeeper10's Avatar
Vet Army
Have a jeeper buds local?. The highsteer is not that hard to install.
