Here's my goal. How do I get there? ('10 2-door Sport)
2.5" coil lifts will typically yield higher than that (3-3.5").
If you don't plan on replacing components such as adj. trackbars, control arms, driveshafts,etc.....I would recommend sticking with:
(1) 2.5" BB(budget boost)
(2) Leveling kit(2" front, 1" rear)
(3) or something like a 2" LIGHT duty OME coil....
Just my thoughts
Just my thoughts
I have a '10 Sport as well. For tires, I put 265/75-16 M/T's on my stock steelies. The height is 32", or about what stock Wrangler tires are when it comes with 17's. With our lousy 3.21 gears, I didn't want to go any bigger.
As for "lift", a buddy with an Unlimited Rubi w/ tow package is doing a lift so I'm going to put on his springs and shocks. Should raise it 1-1.5", I think. Any higher probably wouldn't look good w/ my 32's.
That setup will last me until I decide to do 35's, 5.13's, and a real lift. In the meantime, I think it'll be pretty capable.
I also, de-stickered, cut the front bumper, and cut off the 3rd brakelight and put on a Wilson antenna in its place (yes, there's a CB inside ). It's looking all business.
I would agree with ECHO if you are never going to tow anything with your jeep which if you are leveling the jk would make the jeep squat once you put like a tray or anything heavy on the hitch, also if you have a budget to deal with and the gearing is what was mentioned before about 3.21. If the gearing is 4.11 and you are really not going to be putting any winches or any monstrosity heavy bumper then I would go for a 2.5BB like TeraFlex and put on a 285x70 tire which will give you about 34.8" height and you would need some spacers and track bars because your axels will shift. You kinda have to do some more homework and come up with a more narrowed down game plan as to what you want to do with your jk for any of the folks to guide you as to where and which way to go. " Lucy..... you have some esplaining to do " ! Good luck, you'll get it done.
Also, he probably would not *need* trackbars with a 2.5" lift. Many people are running without them (including myself on a 2.5" coil life) just fine. It would give you more adjustability and maybe some better handling, but mine handles better than OEM.
I would just suggest to this guy to get a solid quality 2.5" lift kit (teraflex, OME, even rough country I like mine and the cust service was good when i did have a problem), and some 33" tires. But even some 32" stock rubi BFG takeoffs might suit him the way it sounds and less worry about gearing issues. 33s should be bearable no matter the gear, but would be better if you had 4.10s (doubtful with a base?). If you have a 6spd and get the 33s, just be ready to stay out of 6th sometimes, LOL.
Probably won't be happy otherwise spending the money and not getting much change. A leveling kit and 31" tires - change will be minimal but you'll still need to spent the coin to do it. For a little more, a 2.5" lift and 33s will be a noticable change, but far from outlandish as a lot of people are running 35-37s on daily driven, modded JKs.
This was taken right after I installed my OME lift. It does level out the rake. The tires are 31" (255/75R17) if I remember correctly. I think that you will want 33's to fill the VOID.
EDIT: That OME looks like it gave you more than 2.5" though (maybe even 3.5"?)... a budget boost wouldn't give him this problem, he knows exactly what he will get based on spacer width.
Also my RC 2.5" coil lift gave me a true 2.5", not more...
Teraflex leveling kit and Rubicon take offs. The leveling kit will even the rake and give you a bit of lift, without impacting the ride. The Rubicon take offs are really good tires 32 inches tall and they work really well. You can get them for 1/2 the price of new tires and they are already mounted on some good looking rims. You should be able to do it all for around $650.
Tom
Tom
