Help with winch mount
Old 08-16-2008, 01:56 PM
Default Help with winch mount
I just purchased the Rugged ridge hd modular bumper and the warn m8000 winch. the winch will mount up but the solenoid box wont mount up anywere. WERE DID YOU GUYS PUT IT?????? I need some pictures of how you mounted it.
Old 08-16-2008, 02:40 PM
Dwikto's Avatar
warlok what are you having trouble with. I hav the same set up it is not the easiest job in the world. I think there is a set of bolts holes that are off set for specific winches. you need to use the riight combo. of holes to gt it to line up.
Old 08-16-2008, 02:41 PM
Dwikto's Avatar
did you buy the solinoid bracket?
if not order one and zip tie it in the mean time
Old 08-16-2008, 02:45 PM
Dwikto's Avatar
Old 08-16-2008, 02:50 PM
Dwikto's Avatar
with bracket
Old 08-16-2008, 02:53 PM
RedneckJeep's Avatar
Originally Posted by Dwikto
Show off....
Old 08-16-2008, 03:49 PM
Dwikto's Avatar
no that was to show the solinoid mount i sware
Old 08-16-2008, 04:53 PM
Ya I didnt get the solenoid bracket but i like your set up.....Thanks and i like the mounting of yours but can i get a close up of the way you mounted the box on top of the winch.
If that makes sense.
Old 08-16-2008, 07:44 PM
02blujpx's Avatar
its mounted on top of the winch with solenoid bracket
Old 08-16-2008, 08:16 PM
Dwikto's Avatar
yeah that is correct. the first picture is showing how it was mounted before the braket the the second shows you how i mounted it with the braket. i recommend the bracket it makes life a little easier and it is only 10.00 i think. otherwise do it like the first pic.
dan
Quick Reply: Help with winch mount
