Help Warrior hood mount hi lift
Old 08-27-2010 | 08:38 PM
Scootersjk's Avatar
Default Help Warrior hood mount hi lift
I just installed the Warrior hood mount kit for the hi lift jack. The problem I am having is that the windshield wash is spraying all over the jack, not getting to the windshield, and running all down the hood of my jeep.WTF. Anyone else have this issue and any suggestions to fix it? Am I doing something wrong? I CAN NOT IMAGINE A COMPANY LIKE WARRIOR WOULD PUT THIS PRODUCT OU WITH THIS ISSUE!!!!!
Old 08-27-2010 | 08:43 PM
rmdchewie's Avatar
I've seen this with a couple of hood mounts that's why I decided to make my own. That said, can you turn the jack so the handle is closer to the windshield or vise versa or will it then hit your cowl?
Old 08-27-2010 | 08:46 PM
Scootersjk's Avatar
Already turned handle towards the front it is spraying right onto the jack
Old 08-27-2010 | 09:05 PM
rmdchewie's Avatar
That sucks but as stated in my last post. That's why I made my own. I'd be calling Warrior and asking them WTF?
Old 08-27-2010 | 09:29 PM
Scootersjk's Avatar
Found someone that used the tuff stuff hood rack with no problem, looks like it mounts forward of the sprayer. Thats what i get for trying to save $50. Back to Quadratec!!!!
Old 08-28-2010 | 03:09 AM
Mark Doiron's Avatar
Veteran: Air ForceFJOTM Winner
Found someone that used the tuff stuff hood rack with no problem ...
The Tough Stuff hood mount does not have this problem. I've used it with the Hi-Lift, then with shovel/axe combo (after installing rear bumper that now holds the Hi-Lift). Tough Stuff does provide instructions and a couple washers to shim the mount should it interfere, but I did not find them necessary in my install. Here are my write-up and a few pic's ...
ToughStuff Hi-lift Hood Mount Write-up
And with shovel and axe ...
