Help! Total noob here. Questions about my used JK
You also have front and rear adjustable track bars.
Your rear sway bar link looks stock too, usually that gets changed out to a longer or adjustable one when you add the lift.
Lastly, it looks like you didn't get the K13 recall on the front inner fenders rubbing the brake lines. The fix is a new bolt to hold the fender in and to hack up the bottom of the inner fenders. If there was any wear on the brake lines they replace them. The recall is for all jeeps built up to August 2009.
As for the rear anti-swaybar links that someone mentioned: Most coil spring lifts come with replacement links for the rear axle so that anti-swaybar can be in a more effective position to operate (the ends of it generally parallel to the ground at normal ride height). You can then take the rear links and move them to the front for the same reason--BUT, moving the rear ones up is not necessary if you already have quick disconnects for the lift height. Again, proper angle for the anti-swaybar is with it parallel to the ground.
BTW: I agree that those are Rough Country RC 2.2 shocks--I used to own a set. Keep an eye on them. Mine started leaking pretty quickly--but that was three years ago. RC has a reputation of being good about replacing them, but I ended up installing Teraflex instead.
