Help with teraflex lift
Sponsoring Manufacturer
Can you post a pic showing the whole front trackbar? Have you grease your flex joints when you get your oil changed? When was the last time you rotated and balanced yours tires or had a alignment done?
Rotate tires every 3k or so due to type of tires I am running. Grease all the time due to how much noise lift kit makes, wife does like like the noise, I tell her its a jeep thing but there is a lot of noise, squeeks.
Dont want to take it in for an alignment until I correct problem. (s)
Will go take a picture but it takes some time for me to load up.
Again, would changing the track bar location using your bracket solve some of my steering problem?
Looks like you got one of the earlier model jks trackbars that had some flex in them, so much so they'd snap. Also, it may just be the angle of the pic, but your driverside coil looks like it has a serious forward bow in relation to the bumpstop, is this true?
some jks tb probs
https://www.jk-forum.com/forums/show...t=jks+trackbar
some jks tb probs
