Help Superchips
Help Superchips
I just bought a Superchip for my 2007 JK.
The program is asking for high and low Transfer case
Can anyone tell me what the stock Transfer case High and low is?
If I recall correctly I belive the SC reads the puter and does this value for you. BUT if you changed to a differnt Transfer case you can change the values.
Just like when you first adjusted the gears it knew what you had when you were stock. Because it stores all the data that is in the puter
Originally Posted by SilverJK12
This is correct. It looks At stock system. If you change gears you change it on sc. Simple as that
So to the OP leave it where it is and enjoy the new tune.
