HELP! Steering wheel shimmy that wont go away!
Is it possible that your control arms moved a little? Set in ground loosen and rock jeep back and forth then re tq bolts and drive. Mine loosen a little of 1000 miles offroad and when I did this shakes went away
A fellow keeper had the same issue. Same fix from the off road shop. Once he got it back the problem came back.
in the end it was his tires. They were 50% worn but balanced fine. He put new tires on and problem went away.
If the shop has some new stock take offs kicking around i would have them test with those after the hardware listed has been done.
If you are close to needing new tires pull the trigger now.
