Help! Squeak Noise Problem
Old 06-10-2012 | 10:55 AM
davidslavin's Avatar
Default Help! Squeak Noise Problem
So, I had a Pro Comp 2.5" lift kit with ES9000 shocks installed on my JK 2-door Wrangler X about a year ago. Recently, I have begun to hear squeaking sounds when I go over bumps or abruptly apply the brakes. This has begun to worry me and I am scared that something might break if I do not figure out what it is. Any thoughts?
Old 06-10-2012 | 11:07 AM
deaner23's Avatar
That's funny bc I have the same issue. Like he said tho, something's just loose bc I've had it happen before and once you tighten the bolts it went away
Old 07-12-2012 | 06:14 PM
Thanks. Seems like it worked. Also, spraying lube on the suspension helped.
