HELP - small wire from JK wiring loom by mistake to the PLUS on battery, should MINUS
All,
I did something incredibly STUPID today, put a small wire from the main loom (see picture) to the PLUS instead of MINUS on battery, when connected there was a click sound from the engine top (nothing I was worried about at that time), tried to start, all lights come on by no starter motor engagement, not even the usual solenoid........ obviously knew something was wrong, related it straight away to this cable as in only choose put the wire to the PLUS as it was the shorter route....... I was changing the battery at the time, didn't think at all..
JEEP won't start, nothing apart from lights on my dash........ AM I TOTALLY SCREWED? I have no idea where to start...... HELP HELP HELP
Are there any fuses I now need to replace........ I am desperate did I blow up the cars computer.......
Well I'm not sure what all is powered from that harness, but is sounds like you have blown at least one, if not more than one , fuse. I would start by checking the fuses to see which are blown, replace them, and go from there. Perhaps then disconnect the power for a few minutes, to give the computer a chance to reset itself, and hope that everything works after reconnecting battery.
You may have blown a relay, or a fuse. I hope nothing more serious than that was damaged.
There is likely a fuse to prevent serious damage to delicate components.
Thank guys, I have disconnect the battery and checked all the fuses.......... nothing I can find so far...... am I over looking something.
I reversed my jeep this morning to get beter access to the battery compartment, so it started no problem (never had a problem like this..... got jeeps a my life)
I am in Brunei (expat) so there is a dealer but not sure if he can do anything......
Borneo safari end of this week..... not sure if I am going to make it.
Cheers,
Mark
Cheers,
Mark
If that wire is supposed to be connected to the negative terminal, it's just a ground wire. Connecting it to the positive terminal would be a direct short. That's not good for the battery.
Have you checked the condition of the battery since this happened? How long was it connected to the positive terminal.
What can I do...... would it help to trailer it to the JEEP dealer to get it hooked up on the computer? I am totally desperate......
No smoke or smell though, nothing what so every.....
Battery still OK.
cheers,
Mark
While the wire was hooked to the positive terminal, it would have been a direct short. It should have gotten pretty hot.
See what the battery voltage drops to while you are trying to start it.
At this point, if everything is checking out, battery, no blown relays, fuses, I would be thinking the brains of the operation are scrambled! It may be time to get it connected to a dealer computer to run a diagnostics test.
Indeed I would have thought, for a short the wire should be really hot, if not burning but nothing what so ever........ Other feedback I got was that I potentially could have activated the immobiliser, didn't know Jeep had an immobiliser but again anything will do.
I have had my jeep on a transporter this afternoon of to the Jeep dealer in the capital, they are going to hook it up to the computer tomorrow, fingers crossed.
Good night...... almost 2300hrs hrs
cheers,
Mark
cheers,
Mark
