HELP!!! Rear outer axle seal leaking again!!
I installed a set of Nitros axle shafts in my 09 Rubicon and the drive side had a leak after the install. These axles come ready to bolt in, everything is pressed on. So after a couple of days, the seal started to leak. I checked everything and re installed them again and started to leak again. Went down to my local shop and had new seal and bearings pressed on. Now its leaking again. It did not leak before I installed the new axle shafts. What am I missing?
rubiconjk09,
The problem may be the axle shaft isn't smooth where the seal rides on it, or the axle shaft isn't concentric with the seal.
Are you sure the seal is installed with the open side toward the differential?
There is always the possibility what you are seeing is brake fluid leaking.
He's talking about the rear axle bearing. There should always be some oil in the rear axle tube. Otherwise, the bearing would run dry and fail. No need to put silicone sealant on the outside of the bearing race. Even if you did, the oil will go through the bearing rollers anyway, as it's supposed to. rubiconjk09, The problem may be the axle shaft isn't smooth where the seal rides on it, or the axle shaft isn't concentric with the seal. Are you sure the seal is installed with the open side toward the differential? There is always the possibility what you are seeing is brake fluid leaking.
