Help please! :( (tire size question)
I have posted a question on this and also searched a TON on this. Folks, I need a simple yes or no answer to this and preferable from those that have ran this set up.
I have a 2010 Unlimited Sport.
Currently its all stock but i want to get new rims. I'm am getting Cragar 16x8 soft 8s with 5" backspacing and +12.00mm offset.
HERE IS MY QUESTION FOR YOU.
- Will 285/75/16s rub AT ALL on this rim on stock suspension with no lift??????? I am not getting a lift. And I do not want to get spacers.![crazyeyes](https://www.jk-forum.com/forums/images/smilies/crazyeyes.gif)
I just need to know if this will rub at full turn, at full flex, at all. I sure appreciate your help! I am about to buy tires and rims and just can't figure this out. I am hearing from some "yes they will rub" and some say "I am running that set-up and no problems." I will be doing some off-roading so take that into account. If these will rub, I guess 265/75/16s are in order huh. Thanks guys!!!!!
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
With all the variables, NO ONE can give you a definite answer. Just best guesses based on their specific setups. My opinion - get the bigger tires and deal with any rubbing if/when it happens.
You can easily add a few washers to bring in the steer stops. Or trim that cheap plastic skid. Or trim the lip on the fenders. Or add a bit more bumpstop. Or add small coil spacers. Or add a body lift. Or...
I will tell you this though. I have steel 16" rims with 5" backspacing. When I first put them on with my tires, I didn't have a lift and they BARELY rubbed. I had to be turning all the way to the left hard and then they'd rub a little. I honestly think you'd be fine. My 35" tire measurement was 315/75/16 btw. So they're just a little bit wider I believe than the 265/75/16's. I think that first number is the tread width.
Someone please correct me if I'm wrong though.
With Metric sizing the first number is the width, the second number is the height in percentage of width, and the third number is rim diameter. So, 315 are 30 mm wider than 285, or 0.8 inches (315mm=12.4in, 285mm=11.2in).
Stock backspacing is 6.25 inches (at least for my wheels).
Don't know if they will rub. I think the change in backspacing will offset the change in width. But you're also increasing the overall diameter 0.75 inches.
![Clap](https://www.jk-forum.com/forums/images/smilies/clap2.gif)
![Big Grin](https://www.jk-forum.com/forums/images/smilies/biggrin.png)
Anyone else with thoughts on this? Anyone out there running 285/75/16s on stock suspension with 16x8 rims with 5" of BS???? Would like to hear from some more people so I can feel all warm and fuzzy about it. ha ![Big Grin](https://www.jk-forum.com/forums/images/smilies/biggrin.png)
Help me pick a tire!![crazyeyes](https://www.jk-forum.com/forums/images/smilies/crazyeyes.gif)
a) 285/75/16s
b) 265/75/16s
Edit: So the 265s (I'm looking at getting the TreadWright Warden ATs by the way) are smaller diameter than my current Wrangler SR-As from what I'm seeing in my research....is that right??? :(
I think I have sold my current rims and tires so time to order my new rims and tires!
Thanks!
a) 285/75/16s
b) 265/75/16s
Thanks!
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
