Help please. Death wobble
#22
SS. lower tire pressure are not cures for DW - you've only masked the issue and setting yourself up or your front end up for eventual failure.
make sure your caster is closer to stock - your control arms should not be maxed out - which control arms do you have and at what distance center to center did you begin?
are your trackbar and drag link parallel to each other?
just in case:
The front lower arms are used to either regain lost wheel base from a lift or to adjust the angle of the front axle for correct caster alignment, or both.
The front upper arms are used to adjust the angle of the front axle for correct caster alignment specs if the front lower arms were used to regain wheel base.
just in case:
#23
just in case:
just in case:
The SS can cause death wobble if it is faulty. I just took a 500 km trip on a rather bumpy hwy and the jeep was fine.
I have put the tire pressure back to stock 35 psi and the toe is back to oe speck. The only thing that is no longer in oe spec is the castor. It is at 6.3 degrees and will stay that way since it is working.
The last thing I need to replace is my u joints in the from axel.
And while I'm at it I will probably install new seals for the axel.
