Help!!!!!!! Please!!!
Bad shock?
I had a 4" Rough Country on my CJ7. It would run the smaller 33" tires no problem on the street / trail. Put the larger ones on and death wobble from Haites on the street!
Spent days going over the front end geometry and $$ balancing tires, and alignmnets....... found a "squishy" RS9000 shock and replaced it on the passenger front and no more death wobble!
If you have the "cheap" shocks that came with the lift try upgrading the front 2 first. (if you have the $$ upgrade all 4 corners).
Just a thought. It's what corrected my issue... Godd luck, hope that helps?
Schlep.
Schlep.
Rebalance didn't work, try rotating the tires. If it goes away its a likely a wheel/tire issue.If not its a suspension issue. How many miles are on your lift/ shocks?
I believe i found the issue my upper mount where my trac bar goes in is tight as can be but i think it has worn the hole where the bolt goes in bigger so it is letting it move just a little bit has to be my problem thanks for the help guys!!
