Help please
Well a common part is the Pressure Regulating Solenoids.
The solenoids receive electrical power from the Transmission Control Relay through a single wire. The TCM energizes or operates the solenoids individually by grounding the return wire of the solenoid needed. When a solenoid is energized, the solenoid valve shifts, and a fluid passage is opened or closed (vented or applied), depending on its default operating state. The result is an apply or release of a frictional element.
The 2/4 and UD solenoids are normally applied, which allows fluid to pass through in their relaxed or "off" state. By design, this allows transmission limp-in (P,R,N,2) in the event of an electrical failure.
The continuity of the solenoids and circuits are periodically tested. Each solenoid is turned on or off depending on its current state. An inductive spike should be detected by the TCM during this test. If no spike is detected, the circuit is tested again to verify the failure. In addition to the periodic testing, the solenoid circuits are tested if a speed ratio or pressure switch error occurs.
Or...
NUMBER: 21-001-08 REV. B
GROUP: Transmission
DATE: February 15, 2008
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-001-08 REV. A, DATED JANUARY 15, 2008, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT REVISIONS.
NEW SOFTWARE HAS BEEN ADDED FOR THE JK MODELS.
THE StarSCAN(R) FLASH FILES FOR THIS BULLETIN MUST BE RETRIEVED FROM THE INTERNET.
StarSCAN(R) SOFTWARE LEVEL MUST BE AT RELEASE 8.04 OR HIGHER.
StarMOBILE DESKTOP CLIENT MAY ALSO BE USED TO PERFORM THIS PROCEDURE. StarMOBILE STANDALONE MODE MAY ALSO BE USED TO PERFORM THE FLASH.
SUBJECT:
Flash: Torque Converter Shudder Or 1-2, 2-3 or 3-4 Upshift Bumps
OVERVIEW:
This bulletin involves reprogramming the Powertrain Control Module (PCM) with new software and replacing the torque converter as required.
MODELS:
2007 (JK) Wrangler
NOTE :This bulletin applies to JK models built with a 42RLE automatic transmission (Sales Codes DFF, DGV, or DG2).
SYMPTOM/CONDITION:
The vehicle operator may experience one or more of the following symptoms:
1. Transmission Shudder - (42RLE)
a. This condition can only occur after the vehicle has been driven and the torque convertor is past the break in period. Torque Converter break in can be confirmed with the StarSCAN(R).
b. If experienced, the shudder may occur when the transmission temperature is between 38°C and 54°(100°F and 130°F) during steady state driving with the torque convertor in partial lock (EMCC) operation. The shudder feels like the vehicle is being driven over rumble strips.
2. 1-2, 2-3 or 3-4 Upshift bumps
DIAGNOSIS:
Using a Scan Tool (StarSCAN(R)) with the appropriate Diagnostic Procedures available in TechCONNECT, verify all engine/transmission systems are functioning as designed. If DTC's are present record them on the repair order and repair as necessary before proceeding further with this bulletin.
If the vehicle operator describes the Symptom/Conditions and they can be verified, perform the appropriate Repair Procedure.
PARTS REQUIRED:
SPECIAL TOOLS / EQUIPMENT REQUIRED:
REPAIR PROCEDURE - USING THE INTERNET TO RETRIEVE THE FLASH FILE:
1. Does vehicle exhibit torque converter shudder with or without a 1-2, 2-3 or 3-4 Upshift Improvements?
a. Yes >>> Proceed to Step # 3.
b. No >>> Proceed to Step # 2.
2. Reprogram the PCM only with the latest software using the flash procedure listed in the flash procedure below. Replacing the Torque Converter is not necessary if the vehicle only has the 1-2, 2-3 or 3-4 Upshift Improvements.
3. Replace the Torque Converter (p/n 05093944AB) - Follow detailed service procedures listed in DealerCONNECT > TechCONNECT for Torque Converter replacement.
NOTE :The PCM must be flash reprogrammed with new software when a new torque converter is installed on the vehicle.
4. Reprogram the PCM with the latest software. Follow the detailed service procedures available in DealerCONNECT/TECHCONNECT, Refer To 8 - Electrical/Electronic Control Modules/Powertrain Control Module - Standard Procedure PCM/ECM Programming - Gas. After PCM reprogramming, the following must be performed:
a. Clear the Variable Line Pressure (VLP) Counters, found in the StarSCAN(R) Misc Function Menu. VLP Clear Counters must be completed on all models with a 42RLE transmission.
b. Clear any DTC's that may have been set in other modules due to reprogramming.
c. Perform the Quick Learn function, found in the StarSCAN(R) Misc Function Menu.
5. Type the necessary information on the "Authorized Modification Label" p/n 04275086AB and attach it near the VECI label.
POLICY:
Reimbursable within the provisions of the warranty.
GROUP: Transmission
SUBJECT:
OVERVIEW:
MODELS:
2007 (JK) Wrangler
SYMPTOM/CONDITION:
DIAGNOSIS:
PARTS REQUIRED:
POLICY:
They did change out some solenoid in the trans, before they changed out the whole transmission. I'm still going nuts here. After they changed out the Transmission, how in the world would it still be shifting the same way?
Or...
GROUP: Transmission
SUBJECT:
OVERVIEW:
MODELS:
2007 (JK) Wrangler
SYMPTOM/CONDITION:
DIAGNOSIS:
PARTS REQUIRED:
POLICY:
TIME ALLOWANCE:
FAILURE CODE:
Disclaimer :This bulletin is supplied as technical information only and is not an authorization for repair.
GROUP: Transmission
SUBJECT:
OVERVIEW:
MODELS:
2007 (JK) Wrangler
SYMPTOM/CONDITION:
DIAGNOSIS:
PARTS REQUIRED:
POLICY:
TIME ALLOWANCE:
FAILURE CODE:
Are you a transmission mechanic?
It sounds more like the issue we are having. It's hard to explain how it drives. Lets say you take off from a dead stop. When it shifts from 1st to 2nd gear, the acceleration is decreased and then it al almost slams into gear. And then it's the same for 3rd to 4th.
I just got off the phone with Jeep. They changed the Torque converter as well as the Trans. Now I'm more lost. What else could it be?
Just a helicopter mechanic? Lol. 10,000 moving parts and you know where each on goes.
