Help please 2.5 inch suspension lift
Will i have trouble with my axcles going out do to angles i own a 2 door wrangler x i know you run into problems if you go big new to the lifts. but 2.5 is all i want to do and maybe a 1 inch body lift.
You'll be fine, I would go 2in buget boost and 33inch tires. If you go bigger tires you will need to regear.
Make sure you get close to the 2.5" lift. Some coils lift more than advertised and can/will cause rear driveshaft issues. Due to the increased working angle. Your actual axles don't care what you do lift wise.
Tire size will depend on if you are auto/manual and the ring and pinion ratio.
Are you looking to go to a bigger tire size? If so what? You might be better off going with a leveling kit. This will eliminate a lot of expense down the road i.e drive shafts and re-gearing. I know that teraflex is developing a 2 door spring leveling kit right now.... just my
