Help with OME Lift for JK Unlimited
Hello all
Anyone have the install instructions for a OME Lift for JK 4 door?
I have bought it used locally, but just came with 4 coils, 4 shocks and 2 yellow coil packers.
Does the kit came with something else?
Any tips or special instructions or i just have to change coils and shocks?
I will install it on my 2011 JK Unlimited Rubicon.
Regards
Mariano
Santiago, Chile
Regards
Mariano
Santiago, Chile
Originally Posted by mlozano
Hello all
Regards
Mariano
Santiago, Chile
Regards
Mariano
Santiago, Chile
Mine OME kit cam with:
4-springs
4-shocks
2-10mm front spacers (2 yellow coil packers) To help level front to back. I used them, but not required.
2-steel blocks to mount to rear axle for bumpstops (only needed if tall tires 35"+ are used to keep tires from contacting rear fenders but not required).
1-rear frame mounted track bar relocation bracket. Not required but highly recomended by OME. I use a JKS adjustable track bar instead.
Only the axle blocks and the track bar relocation bracket came with instructions.
4-springs
4-shocks
If u can get the part number off the springs they will tell u if u got the light/medium load or the heavy load springs. You'll get closer to a 3+ inch lift from the heavy springs. The amount of lift would determine what additional parts u need.
The kit is the heavy duty one and was used 2 months, after that, he replaced it with an AEV 4.5" Premium lift. I have called the seller and he also have the rear trackbar relocator bracket, nothing else.
I don't plan to disconnect the rear swaybar maybe just the front one that is electric. I will use the Jeep with 285/70R17 Tires (33") and may be change to 35", but not yet.
Any advice prior the install?
Regards
Mariano
I have seen that wite up, but i heard that the lift for 2 door's is different than the unlimited one. I don't see any rear trackbar relocation bracket there.
Regards
Mariano
4-springs
4-shocks
4-springs
4-shocks
http://www.acmejeepparts.com/products/16090_10X_PG.htm
Thanks
Mariano
I needed adjustable trackbars with my OME HD. The rear needed the adjustable bar to keep the sway bar links from rubbing on the tires. I also reversed the bolts and the sway bar links. Check every spot where there could be a conflict.
Is this the bracket that should came with the lift?
Thanks
Mariano
Thanks
Mariano
But I think you would be better off with an adjustable track bar. You can center the rear axle more precise. Also I know the JKS adjustable track bar is for 0"-6" of lift. So if you change lift height or add alot of weight to the Jeep, it grows with it.
It is about twice the price of the bracket, but worth it.
http://store.jksmfg.com/merchant2/me...bar_Components
Take care
