help with oil leak.
Old 09-06-2012, 06:39 PM
Zombie Hunter's Avatar
Originally Posted by snytribe
Thanks for your help. One more question for you of you don't mind. How long did you go with the bad shock? Wondering if I need to replace mine with one of the original one until I get a replacement? Again thanks.
Mine was a slow leak over a period of a month/1,500 miles before I contacted OME. Also it was a rear shock and don't know what percentage of "Shock absorbsion" it had left. The ride did'nt seem to change, just noticed the leak.
It could be dangerous in an invasive manueuver, BUT I would drive it as is, if they can get you a new shock in a week or two.
Old 09-06-2012, 06:59 PM
snytribe's Avatar
Again thanks for the help. I will take it easy to and from work. Hopefully quadratec can get one out soon without a hassle.
Old 09-07-2012, 12:13 PM
snytribe's Avatar
No hassle, new one on its way.
Old 09-07-2012, 03:44 PM
dahreno's Avatar
Default shocks
Just curious , are they sending 4 new shock of the right size? maybe being that they were to long you compressed one to far , and that is the reason it leaked . I would make sure you get what you paid for.
Old 09-08-2012, 06:04 AM
snytribe's Avatar
They are sending one. Hoping there will not be any more problems. At some point I would like to go to a 2.5" lift, and would be nice to already have the shocks. They say this should not be what caused the leak. It is a question I asked. I do not know enough about shocks to know if that could happen.. Will take anyone's two cents on this though.
Old 09-08-2012, 06:13 AM
nvertflyer's Avatar
you really should cycle your suspension and make sure your shocks are not pulling double duty as bump stops... but i can pretty much tell you for certain they are and that this will most likely happen again.your options are to add to your bump stop length and reduce your up travel or get a new set of shocks with the correct travel for your application..
Old 09-08-2012, 08:13 AM
snytribe's Avatar
Would this be a problem during daily driving or just when offload? Any thoughts or the bump stops?
Old 09-08-2012, 08:41 AM
nvertflyer's Avatar
if you wheel your rig a lot then the loss of up travel would be unwanted but if you really only use it on the street then the loss would not really effect you much...kind of depends on what you do with it ...on the positive side you will have more down travel but now at full down travel you may need to extend your brake lines or add coil retainers to prevent your coils from unseating...there really is a balance to a correct suspension set up...
Old 09-08-2012, 10:03 AM
snytribe's Avatar
Thanks, this helps a lot. Obviously I could still use some more help. Would like to add coils for a 2.5" lift. Up from the 1.75" pucks on my stock Sahara coils. Do not off road often. Actually first time was two weeks ago. Liked it a lot and will definitely do it again. Though this will continually to be my daily driver. Do you think that longer bump stops will do the trick until I get new coils?
Old 09-08-2012, 10:44 AM
Warpedguy77's Avatar
I'll have a set of 2.5" Teraflex coils for sale as soon as I get my new Evo coils in this weekend. Just thought I'd put it out there in case you're looking to save a few pennies
Quick Reply: help with oil leak.
