help needed: front swaybar link clearance from coils
Had a local shop install my ome 2" lift, jks front and rear trackbars and jks adj. Quick discos in front about a month ago. Was rotating tires today and noticed that the there is very little clearance (less than 1/4") between the driver side coil and the link while the passenger side has over 1" clearance. As far as i can tell, have had no issues with rubbing against coil on bumps. I also noticed that the passenger side shock is not perfectly centered in the tower (leans forward at bottom just a bit). Is this normal? Or a poor install? Or due to lift?? Us it something that can be or should be corrected? If so, how?
you need an adjustable front track bar to recenter the axle.
edit: your front track bar isnt adjusted correctly.
for the lean, look down at the front lower spring perch. you will see an indentation. the end of the coil should sit down in the groove and against that lip.
Thanks.
Thanks again.
Originally Posted by lopezv123
Will check the lower perch on both sides.
Thanks again.
Also, found some marks on drivers side coil, so link is rubbing a bit on that side
Just checked the coils. They are in correct position.
Anyone else having this issue?
Adjustable arms should solve that, but I'm not sure why it's pushed forward.
