Help me upgrade smartly
Need some suggestions (mostly used for DDing, but like to run through the woods to)
I have been reading many posts and just want to go about my upgrades the right way . . . (2008 Rub, Auto, 2Dr)
Upgrading gears to 5.38 for 37" BFG TA KM2 (Already installed RC 3.25 Susp lift)
Ungrading front and rear track bars (either JK or TF) not sure yet . . . any suggestions?
Ugrading drag link? Don't know which one . . . TeraFlex Trackbar Frame Brace & Drag Link Flip Kit . . . ist this too much for my set up?
Do I need to upgrade the upper/lower front/rear control arms?
Then there is the drive shaft?
Thanks for the advice?
JK-Forum Founder
Is the drag link only effected by the RC 3.25" lift or do the tires add to requiring an upgrade? I am adding 37" tires and was thinking it might be necessary for added stability/.
JK-Forum Founder
you only really need to address your track bar/drag link when lifting your jeep about 4" or more. at this height, the angles on them will be quite steep and this will effect the way your jeep handles. optimally, you want to keep your track bar/drag link parallel to each other and as close to parallel with your axle as possible. tires have no bearing as to whether or not you would need to address your steering components.
Excellent, thanks!!
So I shouldn't worry about getting adjustable front and rear trackbars or the drag link. . . yet? The stock parts should be adequate?
Once I do the regearing and add the tires what should be the area(s) I should upgrade structurally to prevent failure? Are there certain areas that become more stressed and therfore vulnerable?
Are most of these beefy upgardes for serious off road adventures? I will not run my jeep through deep mud but I will climb some hills and rocks . . . I just don't want to snap something if I could have prevented it . . .
JK-Forum Founder
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
Thanks again. Sorry, didn't mean to misinterpret.
There are a lot of hings to consider when modding a jeep and unfortunately there is not hand book that says, step 1 . . . step 2 . . . (is there
I just want to do it smartly and safely without destroying anything.
I will keep reading the posts and thanks for all your help!!
![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
