help me pick a rim for gy duratrac 275/70/18
so a forum member is selling a set of goodyear wrangler duratrac 275 70 18
but i can't seem to find a wheel to fit that tire, tire specs say approved rim width 7.0-8.5
so if you have this size tire what wheel are you runing? i would like a black after market wheel, i allready have an aev 2' spacer lift
please help a newbe out! thanks
thanks for the quick reply, but i would rather just buy some black wheels instead of trying to find sahara take offs, buying wheel spacer's and then painting them black.
![](https://www.jk-forum.com/forums/images/ranks/veteran_air_force.png)
Have you tried Tire Rack & Discount Tire web sites? You'll want 4.5" backspace; 5x5 bolt pattern. Those tires are a little over 11" wide, so in theory, if not airing down too much a 9 inch wide rim should work. There's an ATX Slot w/4" backspace black 10 hole and silver lip $250@. Another option is custom made steel wheels. Good luck.
