Help me with my new lift!
Right now, I'm considering getting this lift...
http://www.roughcountry.com/jeep_jk_3-seriesII.html
Can I keep my stock driveshafts if I keep my swaybars connected?
Will my stock 17s (255/75R17) fit? I have a vague understanding of backspacing, but I don't know how to check what mine are.
And while I'm on it... how long should I anticipate the install to take if I have a shop do it? Originally I was planning on doing it myself, but I'm considering my options to have it done by a shop.
BTW, my lift rides so much better than stock. I was surprised.
I say go with a teraflex 2.5 coil lift and start saving for a driveshaft anyway. U could always add a body lift in the future to get more room for larger tires or add 1 inch coil spacers. with the 2.5 teraflex lift, u will be fine with up to 35s. If u keep the stock wheels, u will need wheel spacers. They cost about 20 bucks, I would just get aftermarket steel rims since it wouldnt be much more money.
ultimately I want to go about 3.5 inches of lift by adding 1" spacers. Thats why I am only getting shock extentions for now.Unless I can use the same shocks for 2.5 or 3.5 lift. I know I will be adding shafts later but just wondering if I will be okay for the 2.5 without them.
I understand the need for all the extra components for the extra lift. I like keeping the belly up instead of a body lift. If I understand correctly you are saying that with 2.5 lift the rear shaft would be more prone to failure if wheeled and could be helped out with the rear arms and and adjusting pinion angle.
Your tires will look a little small, but just save your money for the next year and get some bigger tires and your front driveshaft and you will like the look with the 3.5 lift.
Our sport with RC 3.5 lift and LT285/70R17 HANKOOK DYNAPRO MT
We have a 2011 Rubi now and we are putting the same lift on it as well .
