Help me ID this steering setup
I am currently getting my new to me 16 JKUR up to snuff and when attempting to grease the drag link I noticed some issues. There is no zerk fittings on the offset tie rod ends.
the cap seen on the driver side is missing from the passenger side. There is also no castle nut/cotter pin, however the bolt shaft is bored.
some measurements:
drag link is 44” including the jam nuts
drag link OD is 1.675”
rod end offset is 1.75”
Threaded Rod end (into drag link) 1.167”
does anyone know who makes this stuff and if the ends are serviceable?
there is a logo cast on the rod ends, but I am not familiar
thanks in advance
some measurements:
thanks in advance
I THINK that is a Teraflex TR. Grabbed this pic from reddit -
I bet you find a zerk buried in that grease. Would also make sense since PO had TF stabilizer on that. I bet that po had some wobbles and threw good chunk of money at TF in an effort to conceal it. Hopefully they actually fixed their wobble if that was the case.
Awesome, thanks. Will report back.
edit: definitely looks like this https://teraflex.com/jk-hd-forged-dr...e-rod-kit.html
