Help me form the other side of the pound suspension issues
Hello all I'm in the uk I have currently fitted OME 4" lift springs the front springs are bowing outwards towards the wheels the axel has been centred correctly I used rough country geometry drop brackets could the bowing springs be caused from the geometry brackets not giving correct castor? I appreciate any help with regards to this as in the UK Jeeps are not common it's all
Cheers
Jase
Cheers
Jase
Well if everything is setup right, axle centered I'd double check part numbers for springs make sure there the correct ones. I don't think the geo brackets
Would cause that issue as far as side to side.
The axle looks off-center in your second photo. All of your suspension components should be loose, then give the vehicle a good bounce or three, then snug up your suspension.
The off-center would cause the spring to lean sideways like that. Tightening components before putting the proper weight on them could lead to a condition where things are in a bind when you finally apply the load.
Well the OP stated the axle was and is centered, but I have to agree with you Karls10. Really looking at pic's the driver side
Looks like it's pulled over to pass side, thus the huge bow in pass side spring. Hmm...
Looking at both pictures to me it looks like the coils are not sitting in the correct position. I just went out and verified on my JK and there is a slot for bottom of the springs and on the OP the bitter end of the spring is not seated in the back but up front.
What motor are you do you have? Did you account for the extra weight when ordering the coils? Looking on the Old Man Emu site they specifically asked for different motors and bumpers. I think that may play a factor.
R/
Will
If the axle is to the drivers side then how would both coils bow out towards the wheels, would they not bow in the same direction.
R/
Will
R/
Will
As mentioned, have you checked the part numbers on your coils to ensure they're the correct ones for your build?
Where did you measure from to decide the axle is centered?
When you installed, did you use coil compressors? Were the arms/trackbars/links/etc loosened or disconnected? Wondering if it would help to loosen it all, disconnect the shocks, and drop the axle to let the coils fully extend.
