Help me choose some shocks...
OK, right now I've got the 1.75" BB from Rough Country with the stock shocks....I'm about to install a 3/4" spacer in the front which will put me at around 2.5"/front 1.75"/rear. I need some new, longer shocks to compensate...especially in the front. So, could someone who knows a thing or two about shocks tell me if these are the right lengths I would need??
stock lengths are around....
Front.... 14.5" - 22.25"
Rear..... 15" - 23.25"
These are the ones I'm looking at...
Skyjacker Hydro Front
14.54" - 24.75"
http://www.quadratec.com/products/16016_110.htm
Skyjacker Nitro Rear
15.05" - 25.35"
http://www.quadratec.com/products/16016_238.htm
The only reason I'm leaning towards the Hydro in the front is for the ride....right now I've got Rubi shocks and I want something something a little softer in the front.
Also, right now I don't have any extended bump stops so how badly would I need those with me stepping up to 2.5" from 1.75"?
14.54" - 24.75"
15.05" - 25.35"
So, go Nitro all the way then? I can do that, just wanted a smoother ride than what I'm getting now...I think the Rubi shocks I've got are from a 4-door, maybe they're stiffer?
No foreseeable issues with the lack of extended bump stops you think?
JK-Forum Founder
have you ridden in a jk with skyjacker shocks on? if not, may i recommend that you pick up a set of OME or Bilstein shocks instead. i think you will find that they offer a much more comfortable ride.
JK-Forum Founder
what kind of nitros do you have? skyjacker? good monotube nitro shocks are supposed to be firm and responsive but not necessarily "pretty stiff". while hydros can offer a softer ride, more times than not, they tend to be mushy and are terrible on the rocks.
I started my lift adventure with twin tubes,have since changed up to bilstein manufactured rubican express monotubes(I think it's a custom valved bilstein 5100)on road and off I am totally happy with performance of the monotubes,big improvement over the R.E.twin tubes I started with
JK-Forum Founder
RE's monos were always made by bilstein and ft's "were" made by edelbrock. both were great riding shocks but ft was seeing a lot of quality control problems with the edelbrock (shocks being delivered to them with no charge) and so they have now switched over to bilstein as well - they look pretty much identical.
