Help!!! - Long Arm vs. Short Arm Lift....
#31
4 inches of list does not require new control arms... as someone has said before the jk is a different setup than the tj and can go bigger lift without lots of moification... I don't want you to get scared all of a sudden seeing these huge price tags and long lists of parts... pick a nice package and go from there... call the companys you are interested and pick their brain. GOOD LUCK
#32
Looking around at all the different kits, what is the beni's/cons of straight control arms vs radiused arms? I noticed TF uses a bent control arm (as do many) where-as FT uses straight arms. I was hoping I could get an engineering perspective from one of the TF reps or another suspension designer as what the train of thoughts were behind the decision.
#33
Sponsoring Manufacturer
#34
#35
With the combination of larger/wider tires and rims clearance is gained with arms that are bent in. In the front it allows you to turn more. That way your not maxed out by hitting your tires against a control arm. On the lowers it helpful when your coming up to a obstacle, letting the tires hit first and not turing the arms into sliders. Feel free to give me a call about this.
#36
Sounds like you have no need for a long arm kit... if you really like wheeling a lot you can always add it later. I attached a pic of my jeep at the bottom... I am runnning a 4 inch superlift supspension wift with a 1 inch rear coil spacer to level it out. 3 inches will clear 35's its just all about what you want... I would highly reccomend either superlift that offers a 4 inch lift or black diamond that offers a 3 inch. They are both made by the same company they are high quality and an extremely fair price. Their customer service is by far number one as well. Check 4 wheel parts. com they usually have the best prices!
#37
#39
Looks dumb, that much lift not necessary, just creating high center of balance on a short wheel base.....
idk why people seem to think higher is better/cooler. The higher you go, the more work you have to do to keep decent driveline/steering angles....and you're not getting any better performance out of it.
