Help identifying a wobble cause.
Old 04-22-2012 | 10:13 AM
DelVecc's Avatar
Default Help identifying a wobble cause.
I had a dw problem a few months back, so I image this stemmed from it.
I replaced my track bar and anti sway bar links that went bad. It had stopped my wobbles and all. Recently I have encountered a wobble but only on the left side and its a bit different than the dw vibration. It occurs only when the left tire hits a bump and seems to start wobbling and then corrects itself shortly after. This occurs around 50 to 80mph.
When i blast a bump on the right side no wobbling.
Is this an indication of bad ball joints, wheel bearings something else?
It makes no noise either.
Thanks for the help
Quick Reply: Help identifying a wobble cause.
