Help....I cant figure this out
So i had death wobble today. Just put on a RC 4 inch lift. I double checked all the typical DW issues all bushings look good, all bolts are torqued, had it aligned, tires balanced again.... So the only odd thing i cant figure out is why ive been getting DW and i also have an odd shimmy around 55-60MPH. It dosnt shake it dosnt do anything weird any other time. Im lost im getting fed up checking over everything just to find out it okay. Ive even had a local off road mechanic re check everything and he said it was all good to go....any thoughts out there?????
did you loosen the control arms when you installed the lift and then tighten them up with the jeeps weight on itself setting on the ground ? also check your pitman arm torque.I would also check to see if your axles are centered. did you install adj. trackbars with the lift ? but as stated above might be a balancing issue
Therza, I would like more info on the "dynamic" tire balancing as I have shimmy from 65-70, if you don't mind pm me when you get a chance.
Bregan01, I hope you get it figured out soon man, is it both DW and a shimmy? And does anything in particular set it off?
I got it one time, right after rotating my tires. Not a pleasant experience.
It ended up being that the toe was way out of spec due to a bent tie rod.
I guess the front tires had worn in such a way that it never occurred until
the tire rotation.
the tire rotation.
