Help! have i done damage?!
Me and a friend spent this evening trying to install my rough country body lift. we picked a bad time to do it as we were both tired and made the mistake of miscounting the body mounts. we mised one on each side ( the last one from the back mount) so when jacking the car up we found that only the front two spacers had little room to be removed so we jacked it up higher and higher until they could be removed. we were still unable to remove the back mounts and this was when we realized our mistake and found the last pair of mouts. i understand that this meant that with lifting it higher and higher to fit the front two spacers we were flexing the body between the fram mounts and the jack. Could i have done damage here by bending the body like this?
i hope this all makes sense.
Ouch!
I think no one is answering because we cannot tell from here.
About all you can do is complete the task, tighten the stuff down.
As thin as the sheet metal is, any bending there was just might go back in place.
just trying to get a visual but just get it all together and check the mounting areas after to see what's bent - i doubt you would be able to bend the frame.
I'm assuming you didn't see any tear or enlarged holes on the mounts that weren't removed?
visually there does not seem to be anything that has been bent. the holes seemed fine and the bolts were still perfect. My main concern is that before realizing that there was another mounting point we jacked and jacked until hearing a creaking, cracking noise.
One good thing is that the body mounts are obviously pretty tough lol.
If you heard a crack....you may have one.
Might help to pull the back seat and carpets and do a close visual inspection from inside and outside.
You must of really been determined to lift that thing!
I would button that baby up tight and see how it looks and rides. Even if you find some stress cracks or paint missing about all you can do is shoot some paint on it.
