Help with going to 37s
Hey all. I currently have 305/65r/17s on aev rims. I bought my 2012 sport 6sp with a lift, possibly a 2-2.5 budget boost. I don't wheel, but obviously, I like the look of a mean rig. I saw that the ko2 was a decently light 37, only five lbs heavier than my Mickey's. What are your thoughts on getting the 37s on the Dana 30 if I just sleeve and gusset it? Yay, nay? Oh. I currently have 3.73s and am planning on moving up to 4.56s. Any input is appreciated.
If your driving on the roads, I don't see it as being an issue. There are many sleeved/gusseted D30 JK axles doing off-road work with drivers that are very intentionally soft/easy on the axle and don't have issues. If you want to start jarring the front axle around, spinning tires and rock crawling you start to really push up against the D30 and its physical limits. But again, there are plenty out there that can baby the Dana 30 on 37" rubber and make it work if they keep things soft and gentle. Driving on roads, and not slamming curbs and such, you should be fine.
Since you stated you do not wheel 37's on a D30 is not going to be an issue. I would also suggest checking out a gear chart to see if 4.56's are the right gears for your situation. Additionally I would leave the stock axle shafts and drive shaft in place so in the event you decide to go offroad the weakest link in your front axle is not going to be your ring and pinion.
I am currently running a D30 with 5.13's and an Aussie locker with stock axle and drive shafts. Why because it is my weakest link. My plan is to bump up to 37's when my 35's wear out.
R/
Will
R/
Will
R/
Will
R/
Will
you'll be fine on road and just light off-roading.....I actually believe your axle will benefit by not having a locker in it......open diffs will not put that extra amount of leverage on the axle to cause you problems
