Help a girl out!!
#22
Former Member
Thanks Doc. 50 years of women fighting for equal rights and you figure "Help a girl out !!" is OK as a title? Take 2 Xanax and reply.
#23
:cheers;
#24
Relax guys. Let's see if we can bring calm to this topic...so from what I read she is a girl, she is asking for help... What's the problem? She didn't say "help me out because I am a girl." I think you're either trolling or just misreading the title. I don't read it any different than if she said "help a sister out." :cheers;
#25
Meanwhile, back on topic....
When you add spacers you are putting extra strain on the wheel hubs. You should check the hubs for play. Very easy. They are sealed units. They cannot be repaired but must be replaced. I had one worn enough so when I turned a little to the right the brake pads would rub the disk and make a bit of a grinding noise. Sounds like what you are hearing.
OMIX-ADA 16705.14 - Omix-Ada Replacement Front Hub & Bearing Assembly for 07-15 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
#26
#27
