Help Finding U-Joint
So I hear a rotating knocking sound, get out to find the cap fell off the front passenger side of the U-joint. I have read on here that they are "around $20" but when I call the stealership they quoted me $99 and Autozone says they don't carry them.
Can someone help me out with a part number or something that I can get this U-joint?
I jeep a word document on stuff I might need to remember for my jeep and found this:
Sorry don't know where I stole it from... And its rather embarrassing because its written in word and for a living I tell people not to use word..
U-joints
JK D30: (Spicer 5-760x)
The Mopar part number is 4137757
The following parts may be used as alternates for this part:
• Rockwell/Meritor CP297X
• Borg Warner 114-645
• Neapco 1-0297
• Dana/Spicer 5-297X -- OBSOLETE
• Chrysler 3744918
• Chrysler 4137757
• Chrysler 5083670AA
• Ford D3TZ3249A
• 6273940
• Mopar D-95
• Precision 371
• Neapco 1-0297BF
• Precision RL1325
JK D44: (Custom u-joint)
The Mopar part number is 68017182AA
Spicer Replacement - part number 5004891 in the "Spicer Life" Series ~ $60/ea
U-joints
• Neapco 1-0297
• Chrysler 3744918
• Chrysler 4137757
• Ford D3TZ3249A
• 6273940
• Mopar D-95
• Precision 371
• Neapco 1-0297BF
• Precision RL1325
part of the reason your u joint cap came off is because oem type joints come with c clips instead of full circle clips but the main reason they came off is because they used less than ideal materials to manufacture there axleshafts,this leads to the bores becoming oblong and allowing the caps to spin in the first place...the only real way to correctly fix your problem would be to upgrade to a set of cromo shafts as the bores in yours are already out of tolerance and installing a new joint will most likely result in the same thing happening...if that upgrade is not in the budget now then you can tack weld the end caps and that should keep your caps in place...hope this helps...
U-joints
• Neapco 1-0297
• Chrysler 3744918
• Chrysler 4137757
• Ford D3TZ3249A
• 6273940
• Mopar D-95
• Precision 371
• Neapco 1-0297BF
• Precision RL1325
U-joints
• Neapco 1-0297
• Chrysler 3744918
• Chrysler 4137757
• Ford D3TZ3249A
• 6273940
• Mopar D-95
• Precision 371
• Neapco 1-0297BF
• Precision RL1325
