Help! EMERGENCY! CAR WONT GO INTO GEAR!
Old 04-20-2016 | 03:20 PM
blackhawkspkane's Avatar
Default Help! EMERGENCY! CAR WONT GO INTO GEAR!
My 4 wheel drive didn’t work when i bought my jeep wrangler unlimited sahara a couple months ago back. I wasn’t suppose to take it off of rear wheel but i do when the car is off to do some mods. This time when i moved it to 4 wheel drive the shift came loose. Now the car won’t GO INTO GEAR AND I CANT USE IT! PLEASE HELP ME!!!!
Old 04-20-2016 | 03:25 PM
spmitchell86's Avatar
Can you roll it? It should be rolling to switch the transfer case between 2h and 4h... Not stopped
Old 04-20-2016 | 03:27 PM
jadmt's Avatar
JK-Forum Ambassador
Well I'll ask because everybody else will, why buy something if already not working? Fortunately probably an easy fix. Most likely the transfer case Linkage just popped off it is a common problem. There is a little plastic ball joint that needs replacing most likely
Old 04-20-2016 | 03:30 PM
jordy's Avatar
I'll ask why this is an emergency. Are you stuck on a set of railroad tracks and the gates just came down because a train is coming and you can't move?
Old 04-20-2016 | 03:32 PM
I also was thinking/ first mod should be the 4wd... Haha sorry buddy good luck.
Old 04-20-2016 | 03:34 PM
BrowniesJK's Avatar
2nd this
Old 04-20-2016 | 03:36 PM
Emergency because my dad will beat my ass if i don’t fix it lol
Old 04-20-2016 | 03:37 PM
I need to buy a new U-joint but I’m busy with college and come home in a week
Old 04-20-2016 | 03:41 PM
Describe the 4wd lever some more... It's "loose"? Is it in 4hi or N or 4 lo
Old 04-20-2016 | 03:44 PM
Machoo's Avatar
Wow. So nobody has been real helpful yet.
Ok. I don't have photos right now and I'm on my mobile. So you are going to have to do some research yourself. But if your 4wd lever is moving but just floppy and not connected it can be an easy fix. That linkage is attached in two places. One is under the emergency brake center console. Pain to get to. The other is under the Jeep. Easy to get to. Have someone move the lever while you are under the Jeep and you will be able to see if the plastic piece has broken and the linkage is now free from the transfer case. This will make sense once you see it or do some googling. Mine failed on the trail. I was able to zip tie the linkage back on to the transfer case. And it worked great the whole weekend.
The actual plastic piece is $2.50. Of course I just told you that you can zip tie it in the meantime. This piece has been known to fail. Search the forum I am sure there is a write up. I know there are videos on YouTube.
Good luck. Get it fixed
