Help diagnosing a problem
I noticed yesterday my jeep feels different when turning. The best i can describe it is like this: have you ever had your 4wd engaged on a hard dry surface and you get that wheel hop while turning? (No my 4wd isn't on) That's kinda what this feels like, although more subtle. I feel it more on right turns than left. If it matters, I'm running 33"duratracs, stock rims with spidertrax spacers, and a 2" budget boost. I've had the set up for over a year problem free. I'm gonna take it in to get checked out probably tomorrow but I'd appreciate any advice you guys can give
Sent from my Samsung Galaxy IIIs
Ok. Any suggestions to keep in mind of a good replacement u-joint? If I remember right, the stock ones aren't greasable. I'd like to change that.
You can drill the end caps and install your own flush fittings. I've been thinking of doing that if I can't find greaseable ones when replacement time comes around.
It's mere theory- it would be tough to replicate 'exact' conditions to determine when they would fail but I would agree with Ron- most people will see the roller bearings turn to dust before breaking the center section.
Usually you'll see the outside arms of the cross break off and caps walk out. I was just bringing up awareness of a potential issue, albeit relative in risk to standard joints. I bought nongreaseable since they were what was in stock at the time.
My buddy took a look at it today and confirmed the passenger side u-joint is bad. I ended up going with the greasable ones from NAPA. The areas I wheel in are pretty sandy and the "sugar sand" in the NJ Pine Barrens gets everywhere. At least fresh grease can push some of it out...
