help : choosing an affordable tire carrier to run 35s
whats the best option of the following :
1- Smittybilt Oversized Tire Carrier in Black 129.99 $
Attaches to the factory tailgate using the existing holes and requires no drilling or modifications.
Completely adjustable - Designed to mount up to a 37" Tire or up to 195 lbs.
Engineered to Integrated with existing tailgate and works as one solid unit.
Carrier and tailgate open and close as a single unit.
Adjustable arm eliminates tailgate sag.
Comes in signature series matte black textured finish
2- bestop HighRock 4x4™ Oversize Tire Carrier $254.99
This one-of-a-kind Oversize Tire Carrier is constructed of heavy-duty tubular steel and has a black powder-coated finish to protect against corrosion. The supplied hardware mounts to the tailgate. The tire carrier swings away with the tailgate, making access to the rear area a cinch. The adjustable tension and size settings can accommodate up to a 37” spare tire & hold approximately 200 pounds of weight. A third brake light adapter is included, allowing you to relocate it to the carrier. Works with factory bumpers & most aftermarket rear bumpers.
3- TeraFlex HD Adjustable Spare Tire Mounting Kit 199.99$
The TeraFlex Heavy Duty Adjustable Tire Carrier & Tailgate Reinforcement Kit is designed to carry up to a 37" tire over the most extreme trails and obstacles, and provide easy and immediate access to the rear cargo area with a single action. The reinforcement Kit spreads the load and weight of the tire to more than just one hinge point. Incorporating and using the factory tailgate hinge mounting points spread and separate the load as far apart as possible, resulting in maximum strength and durability.
OR
Smittybilt Spare Tire Relocation Bracket 49.99 $
This simple kit allows you to carry up to a 35" tire without the need of a tire carrier. Manufactured out of 1/4in solid plate. Powder coated for long lasting corrosion resistance.
OR
You should get the tf hd hinge and use the stock tire carrier. Cuz just getting a relocation bracket will help you to carry a 35.but won't help the tailgate itself from breaking apart if you do a lot of offroading
The teraflex is probably your best bet. If you go with either of the other oversized tire carriers go with the smittybilt. It is an exact replica of the bestop and a portion of the price.
