Help or advice
Help or advice
Ok I have a 2.5 inch lift on a 2012 2 door wrangler.its a sky jacker lift. I have 33 inch pro comp mud terrains. My jeep rides pretty stiff and I notice hitting pot holes at slower speeds makes the jeep shake a lil. My questions are. Will better shocks give me a better ride. And what could cause this shake in front end. And it's not death wobble.
Shocks will make for a better ride but before you go and spend your money check a couple of things, check your ball joints, tie rod ends, drag link, track bar bolts, pitman arm and the sector shaft, make sure they are all tight and there is no play in any of that stuff
