Help!!!!!!!!!!!
Help!!!!!!!!!!!
I need some help ASAP!
I pulled out a f250 tonight and was in 4L and due to the situation and placement I was in I think I stressed something. When I drive in 2wd no problems but if I drive in 4H and try to turn in either direction I hear what sounds like rocks grinding. What is this?
Oh and I can drive 30mph and slap it in 4H no issues at that speed just when turning at low speeds.
I have 2011 non Rubi with 5.13 on 35's
Yeah, you aren't supposed to drive in 4h on normal dry roads. It's meant for snowy, ice, muddy, and loose terrain. It is normal to hear those sounds on dry pavement. You might even feel like it's jerking a bit. I hope you are just being overly paranoid about any damage.
Lol that's not normal. Have you ever broke a rear axle shaft and drove around on the street in 4h for 3 weeks waiting on a new drive shaft? I have, more than once. And never heard no damn "rocks" while driving.
I have the same issue, came without an identifiable incident. My mechanic told me my U joints needed replacement but that in the meantime it was not dangerous.
You have 5:13 and a D30. You were not in 4wd pulling an F250 from the front of your Jeep in reverse I hope?
I have turned in 4wd on pavement without hearing a bunch of noise, only feel the drive train bind. You may have damaged the u-joints, hopefully not axle shaft/splines or gears. Start with inspecting the u-joints and that area. If you need to, get with a mechanic. You have 5:13 and a D30. You were not in 4wd pulling an F250 from the front of your Jeep in reverse I hope?
