Help
Old 02-04-2013, 07:10 PM
Fusco10's Avatar
Default Help
Ok need advice on 2012 2 door wrangler sport with a 2.5 lift from terra flex and with 33s. How's ur ride quality. My current lift rides like shit. I need to upgrade. Also do u suggest a different lift?? Thanks
Old 02-04-2013, 07:13 PM
kh202's Avatar
Which 2.5" teraflex? Suspension or budget boost? I have the bb with shock extensions and 35" km2s and no complaints. Rides very close to stock which is fine by me
Old 02-04-2013, 07:18 PM
Fusco10's Avatar
Suspension. Might even go with three inch but not sure if I will have to change alot to run that
Old 02-04-2013, 07:20 PM
kh202's Avatar
You I'll probably get 3" from the 2.5 suspension. Driveshaft is highly recommended for anything over 3" on a 2012
Old 02-04-2013, 07:29 PM
Fusco10's Avatar
Just the front???
Old 02-04-2013, 09:00 PM
Pluke the 2's Avatar
It rides like shit and you want to go higher... Do some research
Old 02-04-2013, 09:42 PM
offthewallsurfer's Avatar
He's obviously doing research, that's why he's asking for help, don't be a douche bag.
Old 02-04-2013, 11:19 PM
BlackRockBurner's Avatar
Disregard.
Old 02-05-2013, 02:28 AM
Fusco10's Avatar
I bought a lift when I got the jeep and did no research. After doing some now I found out that that lift tends to be stiff. So I'm asking for some advice now so I don't make the same mistake twice. So if u have no adive then don't respond. I'll ask my local 4wd store. Maybe they will be more help.
Old 02-05-2013, 02:52 AM
westchester's Avatar
Fusco10. Did you replace the springs so you have Teraflex's 2.5" coil lift ? or did you add plastic pucks and therefore have their Budget Boost ?
Either one, I'd have your lift checked by a garage, as both are popular and rarely get complaints.
Assuming the suspension lift is correctly installed and tight, what psi are you running on the tires ? This is my guess as to your concern. I run 27psi on my 35s with TF 2.5" coil lift and it rides and handles great.
Quick Reply: Help
